Kipon Mor
Newbie
- Joined
- Sep 18, 2014
- Messages
- 2
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 19
I own a 1600 VA sine wave inverter that operates at 240 Volts and charges 24 volt Lead–acid battery. I am planning to make a hybrid inverter that would automatically charge the 24 volts Lead-acid battery with Solar whenever AC mains is not available.
Working of the final hybrid inverter should be as follows:
1. Battery is charged with AC mains whenever available(regular charging).
2. When AC power is not available, the changing automatically switches and continues with solar power ( Using relays?).
I already have a solar charge controller for 24 volts 30A , 12 volt relays, 12 volt transformer, diodes(also other electronic components) and two 12 volt, 60 watts solar panels.
Below is a schematic for better understanding.
Any help would be greatly appreciated.
Thank you.
Thank you.
