HVAC control design problem
mrarslanahmed
Full Member level 2
Full Member level 2
gujranwala pakistan
hi all i need to discuss some issues first i am writing scenario then i will discuss the possible solution and later impact of my solution..
scenario
i have been given duty to control HVAC.. there are two systems installed in the system. i have been asked to cutt-off the system if temperature goes below say T=50 the second should also cut off if temperature goes even below T-5=45 there should also be the bypass system, compressor are being used for tempreture control
solution
i am using T775 honeywell's stand alone temperature controller,
problems or impacts
temperature controller is digital it will shut "off and on" the system at required temperature wont that be a bad for such inductive load..if yes then what should i do .. go for VFDs and temprature controller.. do guide me i am strucked
