[HSPICE] from schematic to netlist
davyzhu
Advanced Member level 1
oriental
Hello all,
I have used HSPICE for a few weeks (mostly cmos analog design), but edit netlist by notepad is not convenient (when number of mosfets more
than 20).
I wish you recommend a easy schematic editor by which the schematic can be transformed to HSPICE netlist. And I wish the node of the circuit can be edit in this schematic editor. BTW, my OS is Windows.
Regards,
Davy
balun pspice netlist
davyzhu said:
Hello all,
than 20).
Regards,
Davy
You might search "spicevision" on google. It is not really a schematic editor. However, I found it is extremely helpful to have a quick view of certain analog subcircuit netlist on my window notebook.
AFAIK, the choice of decent Hspice-friendly schmatic editors is really limited - s-edit, cohesion AMS designer ...
For serious design entry, it is still better off with linux version Cadence IC or Mentor's tools.
(PS. ADS has good schematics entry for windows. However, the netlist translation process caused a lot of trouble for me)
gvim netlist
For windows OS, Workview Office has such tools -- viewdraw.
For Linux OS, IC50 (or 5033) is a good choice.
cadence to tanner shematic translator
Many tools can transform schematics to netlists,but the netlists may need little modifications to be compatible with hspice .You can try PSPICE.
according to HSPICE help, Innoveda's Viewdraw and Mentor's IC station supports HSPICE (I'v not tested any of them!)
u can also other sch editors and netlisters like orcad (needs some netlist edit) or protel (less edit requirement!)
BEST!
generate schematic netlist
Cohesion ECS is another one of popular schematic entry tool which support many customize enviroment and if you would like to do more advance features there is sdk for programing with the tool's API.
You can open the x-window in your windows to browse the shematic from unix/linux . Run your hspice in windows too.
hspice generate .sp file
Hello all, thank you all for your advices, I have searched the tools in google, and my friend advise me to use cadance tools, but it seems too difficult. I'd like to use a editor user friendly like HSPICE UI (hspui), without so much menu items and dialog box. Is it mission impossible?
Regards,
Davy
workview office viewdraw + download
use s-edit(tanner)
sedit can generate the netlist that you need
pspice netlist download
i think you can write a simple perl program to correct the error in the netlists which IC50 generate.
netlist 2 schematic
ECS or composer
spicevision ultraedit
Now I choose Tanner for Sch editor, it can export to .sp file.
Davy Zhu
s-edit netlist
Workview Office's viewdraw is good choice
hspice rf netlist
I had used viewlogic before. It is a good EDA tools for pc. The netlist created from viewlogic can be directly used in the HSPICE. I think you can try it.
micromagic sue for windows
to be fully compatible with hspice, most of the spice version of schematic editor will do, but i recommend PSPICE. you can find freeware schematic also, but make sure they are spice compatible, and the netlist is editable.
hspice netlist mentor graphics
You can use DxDesigner from Mentor Graphics PADS or WG PCB design products.
It is a new version of Viewdraw and can export schematics to Hspice, Pspice and Eldo netlists.
schematic entry ecs netlist
cohesion designer
schematic netlist syntax
I also recommand you to use gvim to edit (for free) your netlist.
It includes a syntax color system :
- comment in blue
- .print, .param, ... in green
- ... in color
You can see important stuff much quicker!
PS: Maybe other editor have a SPICE syntax file viewer.
But I don't think that Ultraedit ($$$) has one.
netlist hspice from composer
recommend workview
schematic user environment
i recommend PSPICE tool in windows system.
ORCAD is very good, it can created *.sp, and do hspice simulation.
