D.A.(Tony)Stewart
Advanced Member level 7
- Joined
- Sep 26, 2007
- Messages
- 9,004
- Helped
- 1,823
- Reputation
- 3,645
- Reaction score
- 2,197
- Trophy points
- 1,413
- Location
- Richmond Hill, ON, Canada
- Activity points
- 59,563
You must consider the PLL is only one of many feedback references need to control a good inverter.
The maximum dissipation in your inverter as well as the demand for micro-grid architecture feedback to indicate what power factor you need to supply or when you may not supply to the grid ( e.g at noon when load is light)
So I suspect in modern grid-tied inverters (GTI's) they sense current supplied, voltage detected in range, surge detection, suppression, phase of power supplied and can respond to SCADA micro-grid controls when off-peak demands prohibit generation on the grid.
There are also digital PLL's which use pulse counter/dividers from stable XTAL clocks that respond to fractional N or pulse-swallow and pulse insertion methods to adjust phase or frequency continuously, ( according to required slew rate)
Solutions to stability of the network with micro-grid architecture with GTI's is a topic familiar with someone I know who teaches at U of T.
