How would i start with interrupt driven IR RC5 using AVR ?
Terminator Electricity
Member level 5
Member level 5
avr interrupt driven ir decode
Hi ,,,
I have successfully made a c code for reception of IR RC5 code using ATmega16 with the help of the avr application notes
BUT i dont know how to write or how to start to write an interrupt driven RC5 IR recever
I am using codevision ,, plz could anyone help me to how to start ? cuz i was totally lost here ,, cuz no reference found on that subject
Thanks
input capture in avr
This is my code for IR RC5 reciever using an ATmega16
Chip type           : ATmega16L
Program type        : Application
Clock frequency     : 7.372800 MHz
Memory model        : Small
External SRAM size  : 0
Data Stack size     : 256
void setup_AVR();
#define CHECKBIT(ADDRESS,BIT) (ADDRESS & (1<<BIT))
#include <mega16.h>
#include <stdio.h>
#include <io.h>
unsigned char temp=0;
unsigned char command[10]={0};
unsigned char system[10]={0};
unsigned char timerH=0;
unsigned char timerL=0;
int bitcnt;                     //number of bits waiting to be recieved
unsigned char ref1;                     // 3/4 bit_time
unsigned char ref2;                     // 5/4 bit_time
int i=6;
int j=5;
int k;
interrupt [TIM0_OVF] void timer0_ovf_isr(void)
timerL++;                              //increments every 255* 1/7.372800 seconds
temp++;
if(temp==255) {temp=0;timerH++;} //increments every 255*255* 1/7.372800  seconds
void main(void)
setup_AVR();
#asm("sei")
while (1)
initialize:   temp=0;
      timerH=0;
detect1:   timerL=0;
detect2:   if(timerH>15)   //If no start bit detected within 132ms
                goto fault;
      if(timerL>102)   //If line high for more than 3.5ms
      goto start1;   //then wait for the first start bit
      if(!CHECKBIT(PIND,2))           //If line is :
           goto detect1;   // PIND=0  low  - jump to detect1 and reset the timer
      else goto detect2;   // PIND=1  high - jump to detect2 and recheck for 3.5 ms of ideal high
start1:      while(CHECKBIT(PIND,2))//keep checking for the first start bit
                 goto fault;   //then exit    printf("5");
      timerL=0;   //Measure halflength of start bit
start2:      while(!CHECKBIT(PIND,2))//Measure halflength of start bit (low level length)
                if(timerL>26)   //If startbit longer than 1.1ms,
      goto fault ;   //   exit
                //timerL = 1/2 bit time
      ref1 =3.0*timerL/2.0;        //ref1 = 3/4 bit time
      ref2 =5.0*ref1/3.0;        //ref2 = 5/4 bit time
                timerL=0;
start3:      while(CHECKBIT(PIND,2))//check if second starting bit is recieved
                if(timerL>ref1)   //If rising edge is too long
      goto fault;   //exit
      bitcnt  =12;   //Receive 12 bits
                j=5;            //For command
                i=5;            //For system
sample:      timerL  =0 ;
                while(timerL<ref1); // wait untill first 1/4 of next bit
                while(bitcnt>0)
      //Now recieving first 7 bits including the toggle bit
      while(bitcnt>6)
           { if (PIND.2==0){                             //The bit recieved is 0
                              system[i]=0;               //store the bit in system
                              i-- ;bitcnt--;             //prepare for the next bit
                              while(!CHECKBIT(PIND,2))   //wait untill the next edge
                                if(timerL>ref2) goto fault;
                              goto sample;               //wait for the next bit
                       else          {                             //The bit recieved is 1
                                        system[i]=1;               //store the bit in system
                                        while(CHECKBIT(PIND,2))    //wait untill the next edge
                //Now recieving last 6 bits
                if(PIND.2==0){                                     //The bit recieved is 0
                                command[j]=0;                      //store the bit in command
                                j-- ;bitcnt--;                     //prepare for the next bit
                                command[j]=1;                       //store the bit in command
printf("aa");
for(k=5;k>=0;k--)
printf("%d",command[k]);
printf("bb");
for(k=5;k>=0;k--)
printf("%d",system[k]);
fault:      goto initialize;
void setup_AVR()
PORTD=0x00;
DDRD=0x00;
TCCR0=0x01;
TCNT0=0x00;
OCR0=0x00;
TIMSK=0x01;
ACSR=0x80;
SFIOR=0x00;
how do i change it to be interrupt driven ? plz help
exit interrupt avr
Sony Protocal
avr ir capture and
Two way can do.
First :
Use input capture pin to detect the IR signal, I'm not sure AVR already provided this feature or not, try to check on data sheet.
Second :
Use one external interrupt plus one timer, start the timer counting when a IR signal come to the external interrupt pin.
interrupt driven rc5
i think input capture is a very fine method,,, got any resources plz?
rc5.h+avr
kittythai said:
http://www.wara.com/modules.php?name=News&file=article&sid=610
Sony Protocal
thanks
BUT this is an indian web site POST the english one .thanks
rc5 by avr
Checked on 16bit Timer, already provided the input capture function via ICP1 pin, try to use this to decode IR signal.:D
