-- Clock process definitions
clk_process :process
begin
clk <= '0';
wait for clk_period/2;
clk <= '1';
end process;
-- Stimulus process
stim_proc: process
file IN1:text ;
variable line_input:line;
variable p1:integer;
begin
file_open(IN1,"E:\OUT1.txt",read_mode);
while not endfile( IN1 ) loop
readline( IN1, line_input );
read( line_input, p1 );
p_in <=to_unsigned(p1,8);
wait for 3 ns;
end loop;
file_close(IN1);
end process;
stim_proc2: process
file OUT1:text;
variable TEMP:integer;
variable line_output:line;
begin
file_open(OUT1,"E:\OUT1.txt", write_mode);
wait for 3 ns;
TEMP:=to_integer(p_out);
write(line_output,TEMP);
writeline( OUT1 ,line_output ) ;
end loop;
file_close(OUT1);
end process;
END;
begin
clk <= '0';
clk <= '1';
end process;
-- Stimulus process
stim_proc: process
file IN1:text ;
begin
file_open(IN1,"E:\IN1.txt",read_mode);
wait for 3 ns;
end loop;
file_close(IN1);
end process;
stim_proc2: process
file OUT1:text;
begin
wait for 3 ns;
end loop;
file_close(OUT1);
end process;
END;
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 LIBRARY ieee; USE ieee.std_logic_1164.ALL; use ieee.numeric_std.all; use std.textio.all; use ieee.std_logic_textio.all; ENTITY x1_tb IS END x1_tb; ARCHITECTURE behavior OF x1_tb IS -- Component Declaration for the Unit Under Test (UUT) COMPONENT x1 PORT( clk : in std_logic; p_in : in unsigned(7 downto 0); p_out : out unsigned(7 downto 0) ); END COMPONENT; --Inputs signal clk : std_logic := '0'; signal p_in : unsigned(7 downto 0) := (others => '0'); --Outputs signal p_out : unsigned(7 downto 0):=(others => '0'); -- Clock period definitions constant clk_period : time := 10 ns; signal i:integer:=0; signal p1:integer; BEGIN -- Instantiate the Unit Under Test (UUT) uut: x1 PORT MAP ( clk => clk, p_in => p_in, p_out => p_out ); -- Clock process definitions clk_process :process begin clk <= '0'; wait for clk_period/2; clk <= '1'; wait for clk_period/2; end process; -- Stimulus process stim_proc: process file infile:text ; variable fstatus:File_open_status; variable in_line:line; variable p1:integer; begin file_open(infile,"E:\in1.txt",read_mode); while not endfile( infile ) loop readline( infile, in_line ); read( in_line, p1 ); p_in <=to_unsigned(p1,8); wait for 10 ns; end loop; file_close(infile); end process; stim_proc2: process file outfile:text; variable fstatus:File_open_status; variable p2:integer; variable out_line:line; begin i<=0; file_open(fstatus,outfile,"E:\out1.txt", write_mode); for i in 0 to 4095 loop wait for 10 ns; p2:=to_integer(p_out); write(out_line,p2); writeline( outfile ,out_line ) ; end loop; file_close(outfile); end process; END;
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 library IEEE; use IEEE.STD_LOGIC_1164.ALL; use ieee.numeric_std.all; use ieee.fixed_float_types.all; use ieee.fixed_pkg.all; ---- entity x1 is generic (m,n : Integer := 64); port(clk : in std_logic; p_in : in unsigned(7 downto 0); p_out : out unsigned(7 downto 0)); end x1; ----- architecture x1_arch of x1 is subtype ufixed7_8 is ufixed (7 downto -8) ; type mat is array (0 to 4355) of unsigned(7 downto 0); --size of image with zero padarray type mat1 is array (0 to 4095) of unsigned(7 downto 0); --size of image without zero padarray type mat2 is array (0 to 4095) of ufixed7_8; signal a,memory : mat :=(others => "00000000"); signal wr_ena : std_logic := '1'; signal temp2 : mat1 :=(others => "00000000"); constant k : integer := (m+2); -------- ufixed----- signal b1 : ufixed7_8 := to_ufixed (0.4, 7, -8); signal b2 : ufixed7_8 := to_ufixed (0.6, 7, -8); signal ip : ufixed7_8 := to_ufixed (1/255 , 7, -8); begin --Read the data in process one to RAM process(clk,wr_ena) variable addr : integer range 0 to 4356 := 0; begin IF (clk'event AND clk = '1') THEN if (wr_ena ='1') then memory(addr) <= p_in; addr :=addr+1; if addr = 4356 then wr_ena <= '0'; end if; else a <= memory ; end if; end if; end process; -- pause the first process forever, Start the second process doing the actual simulation. process(a) variable temp : unsigned(7 downto 0) := "00000000"; variable l : integer := 0; variable temp1 : mat1 :=(others => "00000000"); begin l := 0; for i in 0 to 63 loop for j in 0 to 63 loop temp := a((k)*i+j)+a((k)*i+j+1)+a((k)*i+j+2)+ a((k)*(i+1)+j)+a((k)*(i+1)+j+1)+a((k)*(i+1)+j+2)+ a((k)*(i+2)+j)+a((k)*(i+2)+j+1)+a((k)*(i+2)+j+2); temp1(l) := temp/"00001001"; l := l+1; end loop; end loop; temp2 <= temp1 ; end process; process(temp2) variable temp3 : mat2 :=(others => "0000000000000000"); --???fixed begin for i in temp2'range loop temp3(i) := to_ufixed(temp2(i), 7, -8); --temp3(i) := temp3(i) * ip ; temp3(i) := resize(temp3(i) * ip,7,-8) ; if ( temp3(i) < b1 ) then temp3(i) := to_ufixed(0,7,-8); --?? elsif (temp3(i) > b2) then temp3(i) := to_ufixed(1,7,-8) ; else temp3(i) := resize(to_ufixed(5,7,-8)*temp3(i),7,-8); temp3(i) := temp3(i) - to_ufixed(2,8,-7); end if; temp3(i) := resize(temp3(i)* to_ufixed(255,7,-8),7,-8) ; p_out <= unsigned(to_slv(temp3(i)(7 downto 0))); end loop; end process; end x1_arch;
when I run the simulation,the simulation wont stop,Its first time I write this kind of testbench(reading and writting textfile) and I think I miss sth but I dont know what?!.
thanks
if (Simulation_Complete = '1') then
wait;
end if;
stim_proc2: process
file outfile:text;
begin
i<=0;
wait for 10 ns;
write(out_line,p2);
end loop;
wait for 3*clk_period;
Simulation_Complete <= '1';
end process;
END;
LIBRARY ieee;
use std.textio.all;
ENTITY x1_tb IS
END x1_tb;
COMPONENT x1
PORT(
clk : in std_logic;
END COMPONENT;
--Inputs
--Outputs
signal Simulation_Complete : std_ulogic := '0';
signal p1:integer;
BEGIN
uut: med3 PORT MAP (
clk => clk,
p_in => p_in,
p_out => p_out
begin
clk <= '0';
clk <= '1';
wait;
end if;
end process;
-- Stimulus process
stim_proc: process
file infile:text ;
begin
file_open(infile,"D:\IP1\in1.txt",read_mode);
--wait for 5 ns;
-- Add stimulus here
wait until rising_edge(clk);
end loop;
file_close(infile);
wait;
end process;
stim_proc2: process
file outfile:text;
begin
i<=0;
file_open(fstatus,outfile,"D:\IP1\out1.txt", write_mode);
write(out_line,p2);
end loop;
end process;
END;
I dont get where u mean?You might also end up with scheduling problems when you use wait delays to line up the signals and the clocks.
LIBRARY ieee;
use std.textio.all;
ENTITY x1_tb IS
END x1_tb;
COMPONENT x1
PORT(
clk : in std_logic;
END COMPONENT;
--Inputs
--Outputs
signal i:integer :=0;
signal p1:integer := 0;
BEGIN
uut: x1 PORT MAP (
clk => clk,
p_in => p_in,
p_out => p_out
begin
clk <= '0';
clk <= '1';
wait;
end if;
end process;
-- Stimulus process
stim_proc: process
file infile:text ;
begin
--wait until rising_edge(clk);
wait for 10 ns;
end loop;
file_close(infile);
wait;
end process;
stim_proc2: process
file outfile:text;
begin
i<=0;
wait for 10 ns;
write(out_line,p2);
end loop;
end process;
END;
stim_proc2: process
file outfile:text;
variable k : integer := 0;
begin
k:=0;
-- for i in 0 to 4095 loop
while (k < 4096) loop
write(out_line,p2);
k := k+1;
end loop;
end process;
END;
VHDL for loops are unrolled, they are not software for loops. You should be using a counter and a while loop until the count reaches terminal count. Not exactly sure how the for loop would deal with the wait for 10 ns; statement, I suspect it's ignored, but would have to actually try a test case to be sure.
Actually, as this is a testbench, they are not unrolled, and behave exactly like in software...
begin
l := 0;
l := l+1;
end loop;
end loop;
temp2 <= temp1 ;
