lil_vinn
Newbie level 5
I have a 15v 3.3A ac to dc converter that is hooked up to a heating element (nichrome disc) the disc has a resistance of 2.6 ohms, I want to decrease the temperature of the disc, it is currently around 390 degrees C and I want to get it down to around 290 degrees C, I keep trying to hook up different resistors to decrease the temperature but the resistors keep burning out (shorting out). When it doesn't burn them out the heating element does not heat up and no voltage goes through the heating element. I'm not sure how to wire it so that it can drop to the appropriate temperature and not burn out the resistors or POT's that i've tried. I'm farely certain its because the amperage or volage is too high but I don't know how to make it work.
Thanks,
Justin
---------- Post added at 21:00 ---------- Previous post was at 20:31 ----------
Also, I can get the resistors hooked up correctly so I have the voltage desired (around 11.6v) however, when i hook up the load (heating element) the reading goes right to zero and won't heat up
Thanks,
Justin
