How to wind a 350nH accurate inductor
ahmad_abdulghany
San Jose, California, USA
350nh inductor
Hello,
I want to wind ACCURATELY a 300 and 350nH coils,
Can anyone suggest good site with L calculator
Thanks,
Ahmad,
Air coil ??
If it's so, use Nagaoka formula that can be found everywhere but these coils will absolutely require tuning.
You can not obtain exactly 300nH+-%0.5 tight tolerance with air coils.Also, these values are not standard values as can be found SMD or any kind..
ACCURATELY? - how accurate? - can you measure this accurately? - how accurate is your measurement system?
Standard values are to avoid people having to ask how to make a simple fixed value component.
Standard values ALL have a tolerance. There is no such thing as an exact value in the real world.
Good designers do not require exact values - these are avoided by good design.
The design need only be FIT-FOR-PURPOSE and no better.
Polymath
You should use L meter when winding inductors. Formula gives you no guarantee the coil will be accurate wound.
In EDA there is software in the link / updownload section...
Well, what's the name of that software? I dont know where's the upload section, please copy and paste download link..
Thanks in advance,
Ahmad,
