gn01167661
Newbie level 2
Aye I am currently trying to useXAPP341, from Xilinx to transmitt a Zero(00110000) to PC
here is my code
my clk is 50Mhz
and baud rate i am using 19200 Hz
but it keep sending out random character on hyperTerminal, can anyone tell me what did i do wrong ?
---------- Post added at 15:21 ---------- Previous post was at 15:18 ----------
This is the code I am using provided by Xilinx ... please please help me
here is my code
my clk is 50Mhz
ENTITY main IS port(
clk :in std_logic;
tx :out std_logic
END main;
architecture Behavioral of main is
COMPONENT txmit
PORT(
rst : IN std_logic;
clk16x : IN std_logic;
wrn : IN std_logic;
din : IN std_logic_vector(7 downto 0);
tbre : OUT std_logic;
tsre : OUT std_logic;
sdo : OUT std_logic
END COMPONENT;
SIGNAL rst : std_logic:='1';
SIGNAL clk16x : std_logic:='0';
SIGNAL wrn : std_logic:='0';
SIGNAL din : std_logic_vector(7 downto 0);
SIGNAL tbre : std_logic;
SIGNAL tsre : std_logic;
SIGNAL sdo : std_logic;
SIGNAL COUNTER : std_logic_vector(7 downto 0):= (others => '0');
SIGNAL COUNTER2 : std_logic_vector(2 downto 0):= (others => '0');
BEGIN
clk_process:process(clk)
begin
if(clk'event and clk='1')then
Counter<=Counter+1;
if(Counter>="10100011")then
clk16x<=NOT(clk16x);
Counter<=(others=>'0');
end if;
end if;
end process clk_process;
RST_process:process(clk16x)
begin
if(clk16x'event and clk16x='1')then
if (COUNTER2<="010")then
COUNTER2<=COUNTER2+1;
if((COUNTER2>="001")and (COUNTER2<"010"))then
RST<='0';
wrn<='1';
elsif(COUNTER2>="010")then
wrn<='0';
end if;
end if;
end if;
end process RST_process;
uut: txmit PORT MAP(
rst => rst,
clk16x => clk16x,
wrn => wrn,
din => "00110000",
tbre => tbre,
tsre => tsre,
sdo => tx
END Behavioral;
library ieee ;
use ieee.std_logic_1164.all ;
use ieee.std_logic_arith.all ;
entity txmit is
port (rst,clk16x,wrn : in std_logic ;
din : in std_logic_vector(7 downto 0) ;
tbre : out std_logic ;
tsre : out std_logic ;
sdo : out std_logic
end txmit ;
architecture v1 of txmit is
signal clk1x_enable : std_logic ;
signal tsr : std_logic_vector (7 downto 0) ;
signal tbr : std_logic_vector (7 downto 0) ;
signal parity : std_logic ;
signal clkdiv : unsigned (3 downto 0) ;
signal clk1x : std_logic ;
signal no_bits_sent : unsigned (3 downto 0) ;
signal wrn1 : std_logic ;
signal wrn2 : std_logic ;
begin
process (rst,clk16x)
begin
if rst = '1' then
wrn1 <= '1' ;
wrn2 <= '1' ;
elsif clk16x'event and clk16x = '1' then
wrn2 <= wrn1 ;
wrn1 <= wrn ;
end if ;
end process ;
begin
if rst = '1' then
clk1x_enable <= '0' ;
tbre <= '0' ;
if wrn1 = '0' and wrn2 = '1' then
tbre <= '0' ;
clk1x_enable <= '1' ;
elsif std_logic_vector(no_bits_sent) = "0010" then
tbre <= '1' ;
elsif std_logic_vector(no_bits_sent) = "1101" then
end if ;
end if ;
end process ;
process (rst,wrn)
begin
if rst = '1' then
tbr <= (others => '0') ;
elsif wrn'event and wrn = '0' then
tbr <= din ;
end if ;
end process ;
process (rst,clk16x,clk1x_enable)
begin
if rst = '1' then
clkdiv <= "0000" ;
if clk1x_enable = '1' then
clkdiv <= clkdiv + "0001" ;
end if ;
end if ;
end process ;
clk1x <= clkdiv(3) ;
process (rst,clk1x,no_bits_sent,tbr)
begin
if rst = '1' then
sdo <= '1' ;
tsre <= '1' ;
tsr <= "00000000" ;
parity <= '1' ;
elsif clk1x'event and clk1x = '1' then
if std_logic_vector(no_bits_sent) = "0001" then
tsr <= tbr ;
tsre <= '0' ;
sdo <= '0' ;
elsif std_logic_vector(no_bits_sent) >= "0011" and std_logic_vector(no_bits_sent) <= "1010" then
tsr <= tsr(6 downto 0) & '0' ;
sdo <= tsr(7) ;
parity <= parity xor tsr(7) ;
end if ;
end if ;
end process ;
process (rst,clk1x,clk1x_enable)
begin
if rst = '1' or clk1x_enable = '0' then
no_bits_sent <= "0000" ;
no_bits_sent <= no_bits_sent + "0001" ;
end if ;
end if ;
end process ;
end ;
