andihong
Member level 1
- Joined
- May 13, 2015
- Messages
- 33
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 6
- Activity points
- 216
here my example, if port A i give Voltage, and port B is the output,
is the wiper connected to ground ?
Although the configuration depends on your application, typically you would apply the voltage you wish to attenuate across A and B, for example, V+ on A, GND on B and then taking the resulting voltage (output) from the wiper (C). Such a configuration would yield a voltage range on the wiper (C) from V+ to GND depending on the trimpot adjustment.
What is your specific application?
BigDog
for example, i give V+ 12V on A and i want to get 10V output from trimpot,
i can use V+ on port A and output on port B because if i using ground on Port B and wiper as output, it became 6V ? right ?
Connect A to 12V and B to ground. The output is the Wiper. Connect output to the DAC. Turn the pot until you get 10V at the output.i am new here using Trimpot ( three - leg trimmer potensiometer )..
here the picture i got,
Answer this question:
If you connect V+ on A and GND on wiper (C), what is the result of adjusting the trimpot to its two extreme positions?
Also, what is the intended purpose of the resulting voltage output?
BigDog
@andihong,
Utilizing this method to generate a VREF while not ideal, can be used in a pinch to test your circuit.
However, you certainly would NOT use such a method to power one or more devices, you need to employ a regulated power source.
BigDog
