How to use To Instrument Block in Simulink to send variable Data to Serial Port??
xpress_embedo
India
Hello!! Everyone i am new in Simulink and wants to send data over Serial Port using Serial Port. I came to know about blocks in Instrument Control Toolbox. Serial Send, Serial Receive, To Instrument and Query
As i have to send data, i choose serial send.
I configure the Serial Configuration and then use Serial Send block to send data, get unexpected data. I changed to "To Instrument Block" and read this tutorial
https://www.mathworks.in/help/instr...odels-to-send-and-receive-data.html#brbv5x6-1
to send data to Serial Port.
But Suppose i want to send "xpress_embedo\r\n" whole string to serial port then how can i do this. Please some one help me.
you can send the ascii code, and on the other side(i don't know what you use to recieve the data) for example a micro,scan the data with %c or %s(depending on which micro or which language you use) for a array of characters or string.
in rs232 protocol you can only send a binary data,eventhough matlab sends on multiple formats, but at last it is converted to binary
so you can code your string with an algorithm and send it over com port and recieve the binary data ,and encode it with down to up of your used algorithm
hope this helps :)
you can use serial send block to send data over com port
you can use a constant block to give the input data of serial send block,just be sure to change the sample time from -1(inherieted) to sth else
to istrument block also should work , and many pages i read says it's working fine, but i tested without any result
about the string one , i never heared that u can send data as string
you can do as isaid,code your string as integer in transmiter side and encode it in the reciever side
you can use several blocks in simulink to do that ;)
