how to use single button (switch) for controlling appliances using intrupt
prashanttyagi85
india
dear all
i just want to know that how can i control the different appliances using a single switch with the help of interrupt. let if i press the switch one time then it should make on a light, second time then fan, third time than ac & so on upto minimum 12 appliances
dear all
It would help if u could be more specific, eg, r u using microcontrollers or fpgas in the application. It seemed to me that u need to write a piece of code to interface with the hardware. If that is the case a Finite State Machine approach may be useful.
yes i am using here atmega 16 microcontroller
Ok, than you can easily implement your design writing a Finite State Machine code. If u don't know it you probably must go into a bit of reading. You can find it in any intermediate level Digital Electronics book, also a quick search in the web will help. In my opinion it is worthy as it is a powerful tool.
Cheers,
C.
