How to use simple circuit to converter +5V to -5V
mag
Member level 1
My systerm all are +5V supply,But now have a amp circuit need -5V+-10%---10mA supply,how can I use a simple circuit to converter +5V to -5V.the special charge pump chip all are expensive,I only need a simple circuit.
ITP
See this link
/http://ourworld.compuserve.com/homepages/Bill_Bowden/page10.htm
Regards
Itp
emmos
Member level 2
Hi everybody
i think u can just use the LM7905 regulator to get the -5V as u use LM7805 to get the +5V
hope this helps u
bye
emmos
mag
Member level 1
Sorry,My systerm only have +5V DC source,so I can not use 7905 to generate -5VDC.
ynhe
Full Member level 3
China
Hi
Use CMOS Charge Pump Inverter if output current is not high,such as cat660,max660.
ynhe
Ozonehole2k
Junior Member level 3
LM7905 is yet another linear regulator. You still need a negative voltage to start with. Also, note the voltage drop of these device is not insignificant. In general, use a +7V unregulated supply if you are going to make +5V regulated with 7805; -7V unregulated to make -5V regulated.
There are switchmode power supply ICs that handles the conversion. You can also try more common ICs like MAX232 (yes, the level converter for serial port, 0-5V in => +/- 15V out) or some 555 timer based homebrew switchmode.
hxxttp://ourworld.compuserve.com/homepages/Bill_Bowden/page10.htm
leemarrow
Full Member level 3
here a simple converter using icl7660
neelandan
Member level 1
Terra Firma
Assuming your main circuit is digital, there might be a clock there somewhere. Run it to a spare buffer, and connect a voltage doubler circuit to its output, for a negative voltage (two diodes and two capacitors). Depending on the load, the voltage might come to somewhat above 5 volts.
rauol
Full Member level 6
India
Use a timer 555 as a voltage inverter it will be very cheap at low powers
nebisman
Full Member level 4
The best solutio is to use a charge pump ICL 7660 as described below. This integrated circuit costs less than US 1 thne isn't so expensive. If you want to do it by yourself you can use a digital CMOS buffer as 74HC245 oscillator and capacitors. You can also use a buck converter using a low cost pwm regulator as LM3524 from national.
nebisman
mag
Member level 1
for such suggest,i think 555 is best method.
max660, ICL 7660 also are a good select,but the cost is expansiver than 555.
my project:
use this -5V for amp offset adjusting,and resolution is 300uV,so afraid ripple of 555 circuit will be too large for this application.
alphi
Advanced Member level 1
LC filter can not filter all noise,special for switching power supply.
rauol
Full Member level 6
India
Maxim and LT have some regulators which offer very low noise
adi-niunio
Newbie level 3
mag
Member level 1
charge pump maybe have too large noise, anyone have another good method?
