how to use network analyzer to measure the MW power
yzriver
Member level 2
mw power measure
Can I use the NWA to measure the power, as a power meter? Is it a good way to read the harmonic power and phase?
I didn't see any phase reading for spectrum analyzer.
Thanks.
Some VNAs (Vector Network Analyzer) are able to display the level in dBm other than dB. Depend on VNA model.
Phase. For the phase the concept is different. Knowing Phase, make sense only if you have a iso-frequency "reference". A "Reference" require at least a comparition or normalizzation wich is the simplest type of calibration. But if you calibrate the VNA, you'll get only relative measurement, not absolute power.
So: to get Absolute Level and Phase you should perform 2 different measurement:
1) Read Power level (Uncalibrated VNA)
2) Read Phase (Calibrated VNA and 1 port connected to a Ref Phase Signal)
    yzriver
Thanks a lot!
My VNA is 8510C, could you suggest how to perform a phase calibration?
thanks a again.
