how to use multiple adc chaneels in pic 16f873a
suvaraj
Member level 2
erode
hi to all,
i am using pic16f873a,hitech c compiler.in my project i need to use more than 2 adc channels.any one pls help me the program in hitech c.
thanks in advance,
you have 5 channels built-in your 16f873a if u need extra then why not to use 16f877a which have built-in 8 * 10bit ADC channels.
hi i know u r asked.my question is how to use two different adc inputs in program
Reactions: uks
    uks
just select required ADC channel using "CHS0;CHS1;CHS2" bits in "ADCON0" register and also read ADC section on datasheet.
one thing more that also configure "ADCON1" register to enable required ADC.
pls give me one example program for using RA0&RA1 in one program in hi tech c.(using pic 16f873a)
thank u
Reactions: uks
    uks
#define channel_1  0  /* AN0 */
#define channel_2  1  /* AN1 */
#define channel_3  2  /* AN2 */
Example:
result = AdcRead(channel_1);
unsigned int AdcRead(unsigned char channel)
  unsigned int result;
  unsigned char sample_time = 5U;
  ADCON1 = 0x80U;  /* 10 bit Right justified result, Vdd as +ref, Vss -ref */
  ADCON0 = 0x81U;  /* Conversion clock Fosc/32 */
  ADCON0 |= (unsigned char)(channel << 2U);  /* Select channel 	*/
  while(sample_time--){
  GODONE = 1U;  /* Start conversion  */
  while(GODONE){
  result = ADRESH;
  result <<= 8U;
  result |= ADRESL;
  return result;
/* A to d Function */
Hello.btbass
How we can see result of these 3 analog input channels at different output ports of 16F873A.
best regards,
See this example ADC code in Hi-Tech.
If want read 3 ADC, just store in 3 variable.
value1=read_a2d(0);
value2=read_a2d(1);
value3=read_a2d(2);
engshahrul Salamat Datang ,
Web page, you offered for ADC example is tuk tuk (close).
#include "LibraryHD44780.h"
#include "LibraryADC.h"
Error [141] ; 10.27 can't open include file "LibraryHD44780.h": No such file or directory
If we remove these 2 include headers from code,then also failed in compiling.
We receive this error.
Error [500] ; 0. undefined symbols:
_lcd_init
Do you have any example with leds?
hello,engshahrul
i attached a code,in this code we can control leds on RC4 and RC5.
With RA0.
But if we wish to control led at RC0.
Which second adc pin we should select,to control RC0.
And what changes should be in code?
  • adc_on_leds_16F676.txt
