How to use matlab to make wave from file.dat
ITpro
Member level 2
G2 house Viet Nam
I want to plot a wave which the its data got from experiment , and data was expressed in a file .dat. How can i use matlab to plot this wave
Thanks you :d
try file input output options
If you dont know abt them
simply save the data as m file
and use variable at the top of mfile
such that
data.m%M-FILE
I=
45 45 45 45 45
45 45 45 45 45
45 45 45 45 45
data ........];
now run
data and it will be automatically loaded in Matrix I
use I accordingly to PLOT the appropriate points.
Regards
Robin
    ITpro
MATLAB has several functions (with many options) for reading ASCII text data or binary data from a file. What is the format of the data in your file? If you don't recognize the format, maybe show us a small sample and we will try to help.
Also try searching MATLAB help for "importing text data" or "reading binary data".
After you successfully read the data into a variable, use the "plot" function to display the data. It also has many options.
    ITpro
Thanks you, i has just understood what i must do
I will ask you when i have new problem
Reactions: khishe
    khishe
Today , i have new problem, i dont know where we can find mathematical symbol in matlab as in mathematica , if it dont exist whether we can define it ? use mathematic symbol in picture format
I want to make a program that we can make wave. input is function we define and output is wave . I want to use guide for this problem :d
Can you help me
thanks
Simply type Guide on the Matlab Toolbar
Use appropriate Push Buttons and click on its callback from Property viewer
You will see a M-File being opened
Now type function name or m-file name below the callback function
and it will execute with push buttons.
Regards
Robin
    ITpro
