sarfaraz.ahmed
Junior Member level 1
Hi I am running simulation on ncveriolg through command prompt.
Actually, I want that verilog code should use my library cells.
The library are in the path "/home/sarfaraz.ahmed/techlib/FreePDK45/osu_soc/lib/source/signalstorm/files/gscl45nm.lib"
how I include this library in our verilog code . The verilog code is written here :
module nand(a, b, out);
input a, b, ;
output out;
wire out;
NAND2X1 g118 (a, b, out);
endmodule
I want to use "NAND2X1" by my installed library . how I include and then simulate it correctly ?
Currently, it shows an error on NAND2X1.
Thanks
input a, b, ;
output out;
wire out;
endmodule
Thanks
