How to use ICD2 clone with USB port
samnang39
Full Member level 2
Full Member level 2
Cambodia
Hello
I want to use ICD2 clone with USB port how to do?
Thanks in advance
Just an USB cable...and install driver found at CD from Microchip.
The mine have both.
Are you sure that is not using a similar one, not the provide from Microchip ?
Thanks you but mine have only Serial port COM because mine is clone ICD2
Yes i try already but USB to serial converter can not disable FIFO so cannot work with MPLAB
How to disable FIFO?
LaTeX Commands Quick-Menu:
