HOw to use IC555 as ADC by control pin 5
You can try to configure 555 as voltage-to-frequency(time) converter ..
The voltage can be fed through pin 5 (ac only), but here is much better concept:
Regards,
IanP
you can use the 555 like a outpout PWM on de pin 3, Where this is output you can controller by the pin 5 this is a comparator with two level of de voltage
If there is an voltage on pin 5, it seems approximate to triangle signals, you can compare it to with another signal via OPAMP
the voltage at pin5 determines when the output at pin3 is supposed to switch back(transition).....
thank A.Anand Srinivasan
If u don't mind plZ tell me more detail about the voltage at pin5 determines when the output at pin3 is supposed to switch back
Which level voltage on pin 5 to switch pulse at pin 3
The output (pin3) goes HIGH when the voltage at pins 2 and 6 is below 1/2V(pin5) and jumps back to LOW when the voltage at pins 2 and 6 reaches V(pin5) .. see internal diagram of the 555 timer - there is 2-resistor ladder between pin5 and GND ..
Increasing the input voltage at pin 5 decreases the output oscillation frequency while decreasing the input voltage increases the output oscillation frequency ..
Regards,
IanP
given below is the block diagram of the 555 IC in that you can see that the upper comparators input is given from pin 5 and hence when that voltage is exceeded by the voltage at the pin 6 the comparator switches off the Flip Flop and hence the pulse width is directly proportional to the voltage at pin 5....
can you please post the link that you found this result in... because i'm confused about this result... i would like to go through what it is all about....
actually in that circuit it is assumed that the voltage at pin2 is 2.5V due to the capacitor and the output is 2092 pulses when a input of 15V(pin5) is given...
so 15-2.5V=1/2092 pulses(time period)
so when the difference between pin2 and pin5 is x volts(input) the output would be (2092*(15-2.5))/pulses) volts and adding the 2.5V offset due to the capacitor we get 26150/pulse+2.5V...
