Dec 27, 2011 #1 W wht4665453123 Newbie level 6 Joined Jan 19, 2010 Messages 14 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Location U.S.A. Activity points 1,374 Dear all, I'm using the CR analysis of the GoldenGate simulator to simulate an oscillator. May I know how can I plot the Phase Noise? I remember that in Spectre, we run the PSS then PNOISE so as to see the phase noise. Thank you very much.
Dec 27, 2011 #2 pancho_hideboo Advanced Member level 5 Joined Oct 21, 2006 Messages 2,847 Helped 767 Reputation 1,536 Reaction score 733 Trophy points 1,393 Location Real Homeless Activity points 17,490 In Agilent GoldenGate Simulator there is no separation between master large signal steady state analysis(e.g. PSS) and slave small signal analysis(e.g. PAC, PXF, Pnoise). Simply run Autonomous CR with noise analysis. Last edited: Dec 28, 2011
Dec 27, 2011 #3 W wht4665453123 Newbie level 6 Joined Jan 19, 2010 Messages 14 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Location U.S.A. Activity points 1,374 I got the results after reading your reply. Thank you very much
