It is bit confusing in HFSS as I do not know why they have hidden the commands under Edit, Draw and Modeler ribbons.
Anyways you can mirror it
Edit>Duplicate>Mirror
Edit>Arrange>Mirror
The only difference in two is that first command will duplicate the structure while second one will just mirror it.
My problem is i am not getting how to give the position values.
After using that duplicate option 1st we should select base position right? i have chosen that as the FSR end point position later we have to give the values for dx dy and dz right for that what values i should give??
i am giving the position values for that but it is not exactly 90degree, it is slightly changed i am not getting where i have done wrong
Have a look at the figure I think it should solve your issue.
Be sure that your base position and normal position have same non zero components as you are using mirror command which will keep sure the normality issue
I am not sure if I got your problem correctly have a look.
I use the following command instead of mirror
Edit>Duplicate>Around Axis
As in this case you do not need mirror command
