i am trying to read my image pixels in my verilog code for implementation.i created a sample .coe file containing five 32bit binary values and using core generator i have created a BRAM of width 32 and depth 16 and i have initialized the bram with this .coe file. Now i want to do some multiplications with the values in BRAM. How could i read values from BRAM? Can anyone help me clearly?
But if my definition of 'simply' matches with your definition of 'simply', then all you need to so is to place the address, chip_enable(if any) and read_enable at the rising edge of the clock and then on the data bus you should get your data after 1 or 2 clock cycle latency.
Simple right?
It is a different story if you are indirectly suggesting someone to provide the verilog code.
