How to use Boster Circuit for antena Wifi 2.4Ghz??
i will created the boster Circut for antena wifi my modem.. i have make boster antena for my UHF Television with Transistor BFR90A.
in data sheet BFR90A maximum frequensi 5GHz... i think BFR90A can make the boster Circuit for wifi 2.4Ghz antena..
Your TV antenna is receive only, so you just boost the RF in. WiFi is receive and transmit, so you need a receive path and transmit path and a method of routing the signal to the correct path. A power detector and two switches is typical, but it can also be done with circulators.
As I got you, you would design a TX booster right ??
For this purpose, you can not use BFR90 but you can find many 2.4GHz Medium Power Amplifier in the market, take one and use it.
