How to use battery correctly?
shoivn
Junior Member level 1
Hello!
I'm using mobile phone and laptop.Some body told me that I should charge the batteries only when they're really low so that I could use them for a long time,but another one told me to charge them everytime (always...).So what should I do?
In the old days with nickle-cadmium batteries there was a memory effect. The capacity would decline if you charged them from less than full discharge. NiMH types had a much smaller memory effect. Now Lithium-Ion batteries are used in telephones and computers. These have no memory effect. You can charge them wit a smart charger (which usually comes with the product) whenever you find it convenient.
    shoivn
Thanks for your help! But is it harmful if we continue charging even when the battery is full already? By the way,you mentioned a smart charger.Is it a charger that can turn off when the battery is full?Does it has any functions else?
Batteries (of any kind) will not last forever ..
The ordinary Li-ion battery has 500 to 800 hundred charge cycles ..
The real life span depends on how it is used and cared for ..
See https://ebuybatteries.com/company/battery_faq.htm#battery-life and **broken link removed** for more information ..
Regards,
IanP
The second link was incorrect ..
    shoivn
Smart chargers monitor the battery voltage and temperature to determine when to stop the charge. This is why many computers and telephones only allow you to charge the battery when it is in the product. This is where the smart charger is.
    shoivn
