How to use a Watch Dog Timer?
hameeds01
Advanced Member level 2
Islamabad Pakistan
How to use a Watch Dog Timer? Am I using the WDT in a correct way?? I need a sample code for wdt in CCS C ……
Its not working only it performs task2 :|
#include <16F877A.h>
#fuses XT,WDT,PUT,BROWNOUT,NOPROTECT,NOLVP,NOCPD
#use delay(clock=4000000, RESTART_WDT)
timer0_ISR
restart_wdt()
task1()
main()
setup_wdt(WDT_18MS)
while(true)
restart_wdt()
task2()
Re: WDT help???
You'll never reset a wdt in an isr as it's possible that the program hangs while the timer interrupt is still running.
Reset the wdt at different locations in your application.
Re: WDT help???
Whatz the relationship b/w timer0 &wdt? If I enable wdt then timer0 runs very fast but it runs fine when I disable wdt ????
