The projects are based on PIC chips. but it can easily be re-written to other languages, once u understand the basic workings of the AT keyboard.
For your project, the mcu need to be able to interface correctly with the keyboard. Buffered the key that u type n then u display them on ur matrix leds.
well, try to be more specific. this way we can b more precise to your solution
Re: how to use a keyboard to control the dot matrix display!
you must learn how connect ucontroler to pc-at keyboard and
then write program for dot matrix display
and if you have few port you can use multiplexing...
if he wanna keep data when the power is off must put eeprom or ....) 2-3 battery.
i haven't make that tipe of circuit, i have been read some in the net for this but... think is not so hard to make this
I have schematic and source code from google Schematic and source code here i Make experiment and i change ic with Atmega8535 why LCD no work,IF u can compiler for Atmega8535 share here i will experiment because my circuit is final and no conect to dotmatrix but conect LCD 2x16 only,i'm sorry my speak english is bad
