I am clear about the header (with date, simulator version, timestamp, etc) & the variable definition ($var) sections in the eVCD file.
But I would like to understand how to read an event, direction & value in the value change section (after $dumpports).
For Example,
<header section>
<variable definition section>
$dumpports
<value change section>
#0
pH 0 6 <10
pU 1 2 <20
pD 3 4 <30
pL 5 6 <40
ph 7 8 <50
pl 9 10 <60
pX 11 12 <70
pD 13 14 <80
pZ 15 16 <90
pNNN 15 16 <100
pffff 0000 0000 <110
pflll 0111 0000 <120
$vcdclose #100 $end
For instance, if I know that signal A, toggles for 10 times in a period of 1 ns, through a wave viewer.
How do I map the same signal A, in the above value change section example?
Thanks,
RMK
