cwjcwjcwj said:You are basically looking for a system with spectral efficiency of 2.4 bit/s/Hz. Without considering channel code (parity bit), preamble and etc, a 8-PSK system (with 3 bit/symbol) will do the job perfectly in the ideal case.
cwjcwjcwj said:What is your application? To me, this is quite high data rate. Therefore, if you are using single carrier, there might be a problem with inter symbol interference cause by frequency selective fading channel.
cwjcwjcwj said:I doesn't have much knowledge about underwater communication. As far as I know, the underwater wireless communication suffers from quite severe multipath fading. I think you may need multicarrier system such as OFDM to solve the problem. Is there any constraint for moving from single to multicarrier?
Aya2002 said:yes the OFDM is the best for this problem
Dear Aya2002,Aya2002 said:welcome
Hi,cachep said:Could you let me know how to design a system which can transmit the high data rate ( over 120 Mbps) with the limitted bandwith (50MHz) and use the low frequency (from 0 to 200MHz)?
Thank you very much!
Thanhlongbin said:Hi,cachep said:Could you let me know how to design a system which can transmit the high data rate ( over 120 Mbps) with the limitted bandwith (50MHz) and use the low frequency (from 0 to 200MHz)?
I think, the Ethernet (Fast-ethernet or Gigabit -ethernet) may be usable.
For example: Fast-ethernet 100base-T has:
1. Full duplex 100Mbps
2. "Fundamental frequency" of 31.25 MHz
3. Distance: <100m (UTP cat. 5) or ~ 10km (fiber-optic cable).
Is that OK?
rmreddy said:It would be ideal to know what is the application you are intended to workup this system...
It plays a major role in deciding on system architecture and framework
You didn't mention the range, but may it also could be possible to use optical channel (100BASE-FX ?) but over the air, without wires.cachep said:Thank you Thanhlongbin for your comment. However, I can not use the Ethernet beacuse I need one wireless solution.
