Can any body help me with C++ code for serially transmit data from the computer. The microcontroller (AT89C52) will receive that data. Well I have written the microcontroller's code. Please help me with the C++ code for transmitting data from computer to AT89C52.
Hi te04-0202,
Lot of free applications are readily available in internet which will serve your purpose. Typically they access the PC COM port and send the data you require. You just need to make sure of the physical layer (RS232 / TTL) and the baud rate settings.
One such good software is "COMDEBUG" also known as "WINDMILL".
You can download it for free and start using.
