FYI : I am using Vivado 2017.3 targeting a KC705 board including a Kintex-7 (xc7k325t) FPGA.
I am trying to read data from DDR3 and load it to a FIFO and then send the read data for JESD204 to be read out by DAC.
Within my search, I found that Xilinx has provided a design strategy here, that implements an AXI DMA and FIFO on a Zynq device which has a PS and PL part.
I am trying to transform this design to be compatible with KC705 board and replace the Zynq Processing System with Microblaze. I cannot get a functional design. Can anybody help me to solve this issue?
No one will help you unless you ask VERY specific questions - describing in great detail what you've done and where / how you failed.
I suggest that you break your project into small blocks - each doing a very specific task and start testing.
When something fails post a question and people will try to help.
