How to test insert loss of the Balun? Thanks!
dopradar
Member level 5
Member level 5
Hi all,
How to use single-end port network analyzer to test balun---single end to differential ports?
I have tested three pieces of 2-port S-parameter with three different port loading separately, so there is a question, how to use these parameters to calculate the insert loss of balun?
Are there some papers/documents to introduce this issue? Thanks!
Best Regards!
Dopradar
FANT
Advanced Member level 1
Italy
If you have two balun connect on ethe opposite of the other and divide the attenuation by 2.
Mandi
