Hey Gentleman!
Hi
I think your mean is that you want to test your IGBT ( is intact or not?). if yes, your answer is simple! if you give +15 volts between gate to emitter of your IGBT , Its collector , emitter junction , will become short circuit( approximately). if you can see this behavior , your IGBT is intact.
Regards
Goldsmith
Hey Gentleman!
Hi
Regards
Goldsmith
what do you mean by intact ?
I have taken it out from the inverter. Kindly, provide the circuit (dchematic) to apply +15 V between emitter & gate and what to measure between collector & emitter junction .......... ??
Hey Dude!
Again Hi
My mean by intact is : that can work as well as ( it is not destroyed).
You can test it with this simple circuit
Or you can use a tester in collector to emitter junction.
Respect
Goldsmith
Hey Dude!
Again Hi
You can test it with this simple circuit View attachment 61175
Respect
Goldsmith
Hey Gentleman!
Again hi
My mean is that you can use a voltmeter and if you give a command to gate- emitter of IGBT , ( use my circuit) voltage across The collector emitter will become zero ( approximately) and if you cut the command , from gate to amitter , voltage across The collector to emitter will being +VCC. and you should test each IGBT of this package ( one by one).
And it is very simple.
I hope that this become helpful!
All the best
Goldsmith
