kyungmin1125
Hi all,
I have a constant current out of a switchmode circuit (https://www.onsemi.com/pub_link/Collateral/LM2575-D.PDF). I am getting a 1A DC out of this. The output voltage is variable, depending on the input level.
My goal is to switch this current on and off with a pulse input. I built a switch using 2 NMOS and drove them with 5V pulses that are out of phase. I didn't use an NMOS-PMOS pair because it may not be as symmetrical.
So I have something like the circuit above. You can ignore the IC chip, it just represents a constant current supply out of the node "LEDA". The problem is when I increase the switching frequency from 1kHZ to 5kHz or higher, the AC current through the LEDs die. Why should frequency affect the amount of current through the LEDs? The voltage at the LEDA pin stays constant at different frequencies though, which is why I am confused why frequency matters.
Any help will be appreciated. Thank you!
