ezbentley
Junior Member level 3
I am designing a low voltage(1.8V) Gilbert cell mixer, which includes(from bottom to top) tail current mos, RF input mos, LO switching mos, and resistive load. Since LO has large amplitude, there would be a large common-mode second harmonic of LO at the drain of RF input mos, which may cause the RF input mos to go into triode region, or even feed through to the RF port. Is there any trick to supress the common-mode 2nd order LO signal? Adding a cascode is not really a good solution for low voltage application.
