how to store data in arm7 flash
DCO_81
Member level 1
Germany, south
sam7 iap api
when my arm7 mc downloads a file in his ram I want to store it permanent in the flash. So when I reboot it the data should not get lost. How can I achieve this?
HI
What type of ARM7 are you using :
LPC21xx,TMS470,STR7,SAM7,ADUC7xxx etc
each MC has it's own Flash programming API
All the best
Bobi
I want to save some Data in the Flash of the TMS470R1A256. Does anybody have code examples or a flash API or a documentation?
Hardware:TMS470 - Rowley Crossworks - CrossConnect
Thanks a lot!
RaPo470
Hi
If you wish to save only few parameter :
const unsigned char DAT[0x05,0x06,0x012] the compiler save it automatecly to FLASH memory
All the best
BObi
bobcat1 said:
Hi
All the best
BObi
I want to save some data inn the falsh at running time, not when compiling the program. I want to save data from the ADC or Positions from a motor before the controller loses power!
But thanks anyway - good try!
Best regards
RaPo470
it depends on which flash device u r using.
r u using a nand flash or nor flash.
may be u can post the part number of the flash here.
Which device r u using ?
You want to save this data at External SPI/I2C FLASH or you want to use IAP commands ?
that perticularlty depends on your ARM device type as every device may have diff IAP command s.
Can you Elaborate your application with device Numbers..
I am using the TMS470R1A256 with 256KByte On-Chip-Flash. I want to save the data into the last sector(0x1003E000 - 0x1003FFFF) of this On-Chip-Flash, not in any external SPI-Flash-Memory.
Thanks for your reply.
RaPo470
Hi RaPo470
For that you should check
TMS470 Family – F05 Flash ModuleSoftware Peripheral Driver User’s
Specification -
All the Flash API 's are given into it .
I am trying to make one TMS470R1A256 Eval board if you have any idea pls help me .First point I have stuck is it does not have any Serial Programming utility.
Thanks and Regards
Girish
Hi Girish,
I tried the Flash-API but I couldn't make it working. I am using the Rowley Crossworks (very good and exelent support). In the Datasheets I read that an erase-sector could last 2 or more seconds. This is much to long, when you want to save position datas on power down!
There are EvalBoards from TI or Olimex. They use the JTag-Interface for Programming. For serial programming you have to program a loader and program that loader to the controller( with a JTag programmer). On serial Upload this loader must run in RAM , so you can erase the complete Flash and program the new software (including the loader for the next programming). All in all no easy job, i think so far. A cheep and working programmer is Wiggler on a PC's parallel Port.
I used the Olimex-Board for trying out the Flash-API without success. I could not find the TI-source-code for the Flash-API so debugging is not easy.
Thank you and best regards
RaPo470
