how to store configuration on sim900
faylindstrom
bdg
Hello All,
I want to ask about sim900 at command gprs. I have success to send data via gprs. but when I reset the circuit, I must send all paramater again like port (using AT+CLPORT=xxxxx), apn username password and all..
how to store that configuration? so when board is restart, the board load all parameter from the last session,,,
please help me..
is this using ATE0&W or what..????
thanks...
the port what you use is a dynamically assigned port by the service provider... if only you have a static IP address , after all operation send a command AT&W, that saves the configuration on the flash of the modem....
remember there are few commands and its run time response that cannot be saved in the modems...
To Mr Ckshivaram.
thanks for repply, I will try this now :)
so I must using AT&W after I set all of this command:
AT
AT+CIPMODE=0
AT+CLPORT= "TCP",21300
AT+CIPCSGP=1 ,"wap.xxxxxxx.com"
AT+CSTT="xxxxx","xxxx","xxxx"
AT+CIICR
AT+CIFSR
AT+CIPSTART="TCP","123.123.123.123 ","21300"
AT+CIPSEND
AT&W
Thank you Mr.Ckshivaram
