[SOLVED] How to start PCB Design with Protel?
B
boot_strap
PCB Design..?
how can i start PCB Design with protel..?
Re: PCB Design..?
start from component design using schematic editor and copy the netlist to pcb editor.
PCB Design..?
u can use CAD software Like Orcad and start by shematics and test ur circuit if all is fine then creat a netlist then use layout editor to draw ur circuit then print on ur pcb and go on
PCB Design..?
Schematic->netlist->PCB
PCB layout, Auto-> interact->Manual according your complex of the design. For the beginner auto maybe a good choice u can understand the PCB layout.
Re: PCB Design..?
first, you must draw schematic.
then you need generate netlist from schematic.
finally, you can draw PCB use netlist.
for detail, you can follow protel's example.
best regards
boot_strap said:
how can i start PCB Design with P*otel..?
Re: PCB Design..?
check out protel manual : )
PCB design involves issues such as placing components, routing...
check out here for a few recommendations..
Re: PCB Design..?
visit this site : h**p://www.electronics-lab.com
PCB Design..?
Find a sample project and investigate it.
Re: PCB Design..?
Probably protel (New name is altium designer) cad tool is the easiest to learn and follow the link below to get started and then accelerate the learning speed as you go along.
https://altium.com/Community/Support/LearningGuides/
Tutorials are available from the altium web for each and evry step to be followed in the process of board design.
Re: PCB Design..?
Take care about PCb library
