What is the minimum insulation value? is it around 1 Mega ohms or something bigger than that?Hi,
Both.
* Insulation check against metal case.
* resistance check: each wire against each wire. All three values need to be very identical and relaticely low ohmic.
If the lowest value is less than 85% of the highest value you should be worried.
Yes, I have the megger to test the insulation. Thanks for your help. I really appreciated that.Hi,
Isolation check needs to be done with high voltage. A DVM can't do this.
Do you have a HV isolation check device?
1 MOhm should be sufficient.
