I tried installing IC5033 on Scientific Linux 5.1 I have these problems.
I configured the Bind key by copying all the files from <install_dir>/tools/dfII/sample/local to <install_dir>/tools/dfII/local, and
renamed the cdsinit to .cdsinit.
So far so good.
I edited .bashrc in the /home/user/ folder and it looks like this:
export CDS_ROOT=/home/bogdan/IC5033/
export CDS_INST_DIR=$CDS_ROOT
export CDS_INSTALL_DIR=$CDS_ROOT/tools/dfII
export CDSDIR=$CDS_ROOT/tools
export CDS_Netlisting_Mode=Analog
export MOZILLA_HOME=/usr/bin/netscape
export XKEYSYMDB=$CDS_ROOT/share/cdssetup/tdmX11/XKeysymDB
export XNLSPATH=$CDS_ROOT/share/cdssetup/tdmX11/nls
export CDS_WAVESCAN_JRE_DIR=$CDS_ROOT/tools/jre1.41
export CDS_LIC_FILE=$CDS_ROOT/share/license/cadence_license_full.dat
export LM_LICENSE_FILE=$CDS_ROOT/share/license/cadence_license_full.dat
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$CDS_ROOT/tools/lib:$CDS_INSTALL_DIR/lib
PATH=$PATH:$CDSDIR/bin:$CDSDIR/dfII/bin:$CDSDIR/SKILL06.00/context:$CDSDIR/SKILL06.10/context:$CDSDIR/dracula/bin
# PATH=$PATH:$MMSIM_ROOT/tools/bin:$MMSIM_ROOT/tools/spectre/bin:$CDS_ROOT/tools/bin:$CDS_ROOT/tools/dfII/bin:/usr/sbin
PATH=$CDS_ROOT/tools/bin:$CDS_INSTALL_DIR/bin:$CDS_ROOT/tools/spectre/bin
PATH=$PATH:$CDS_ROOT/tools/bin:$CDS_INSTALL_DIR/bin:$CDS_ROOT/tools/spectre/bin
PATH=$PATH:/bin:/usr/local/bin:/usr/bin:/usr/ucb:/etc:/usr/openwin/bin:/usr/X11R6/bin
export PATH
# .bashrc
# Source global definitions
if [ -f /etc/bashrc ]; then
. /etc/bashrc
fi
# User specific aliases and functions
I copied the license.dat to /home/bogdan/IC5033/share/license/cadence_license_full.dat (as the .bashrc file says). Was there anything else to do because after restarting the konsole and when I try to run icfb& it says:
[1] 4168
[bogdan@localhost ~]$ /home/bogdan/IC5033/tools/dfII/bin/icfb.exe: relocation error: /home/bogdan/IC5033/tools/dfII/bin/icfb.exe: symbol errno, version GLIBC_2.0 not defined in file libc.so.6 with link time reference
[1]+ Exit 127 icfb
Not to good ... I read about it ... it's not that effective ... It gives some other errors:
[bogdan@localhost ~]$ icfb&
[1] 4465
[bogdan@localhost ~]$ /bin/sh: error while loading shared libraries: libdl.so.2: cannot open shared object file: No such file or directory
[1]+ Exit 127 icfb
[bogdan@localhost ~]$ ls
ls: error while loading shared libraries: librt.so.1: cannot open shared object file: No such file or directory
Ok sorry, i had the same problem with the installation of IC5141 on Fedora9, i didn't solve the question, i try to use IC6.10 and that's all ok.
In the past, i have work with IC5033 on Mandrake.
i had all sort of these issues when i tried installing ic5.1 later i found out that its problem with some packages not getting installed. i suggest you go for a complete install of rhel4 if you could. otherwise atleast make sure that you install all glib, gcc and motif packages. hope this solves your problem.
