How to simulation noise in bandgap design?thanks
jonneylu
Member level 1
Member level 1
Hi friends:
Now i am design a bandgap reference,i will simulation the integrated output noise from 10Hz to 100KHz, what's the simulation command can be used in the netlist?
Thanks!
You can use ac and noise analysis in spectra. Then you can use the calculator to get the integration noise
to pfd001:
How to use integrator command?
what about using Hspice, with .ac and .noise command and observe the output or listing file to get the integration noise output
jonneylu said:
to pfd001:
In the analog design enviornment, you can find the calculator in the tools. In the calculator, you can use the integrate
