triquent
Full Member level 3
I tried to add the startup circuit for bandgap voltage reference circuit(Op-amp type). Without the startup circuit I got it work right. I also didn't use the .ic command to setup the initial condition. Now my question is. If I add the startup circuit, how can i simulate it and verify it work? I mean without the startup the circuit willnot work, after add starup it will work and the starup part will not effect the whole circuit. Is this right?
