yuanzy97
Member level 1
Now, I have a MZ modulator used as a electric field sensor. That means when the MZ modulator is in the EM field, the laster throug the MZ modulator will be modulated and the output power will change with the amplitude of the EM field.
Therefore, I want to design the waveguide of the MZ modulator. If I want to use the FDTD method to simulate this structure, I need two sources. One is laster, another is EM field. Is there any FDTD software which can do this simualtion?
Thank you vey much.
Thank you vey much.
