How to simulate the bias circuits for amplifiers?
saulbit
Member level 4
Member level 4
I have to design a 10GHz~16GHz amplifer bias circuits. The amplifer is a MMIC from Hittite. However, I have to design the bias circuit. I have disigned some high impedance microstrip line, in order to form some inductor. The DC voltage pad is the end of the high impedance microstrip line. How can I simulate in the HFSS design? The DC Pad should be equal to open circuit or short circuit? In the traditional tutorials, the voltage sources shoul be equal to short circuit, but this may not be the case in microwave frequency band? I just wonder it. If the short circuit is the case, how can I simulate in HFSS? If not, how can I set the attribute of DC pad in the HFSS?
Thanks in advance, any reply is welcome.
hi, I think HFSS simulate the passive model, not including active circuit. You only simulate the parts in your MMIC circuit. After then, export the S parameters to ADS or other tools. hope to helpful.
