vig94
Newbie level 1
Hi. I am a Masters Student who requires this as a first step to start my Thesis, and I am new to matlab signal processing. I have theoretical knowledge but I just started Matlab implementation of the same. Also I am completely new to the FMCW tool chain. I have to create an FMCW signal, transmit, receive and mix them to get the IF signal, and inturn get the radar 2D matrix for post processing. But I my 2nd FFT doesnt give the correct value of velocity. I set the chirp parameters and thus obtain the Vmax and Rmax values.
There are 2 IF signals created : one the theoretical, obtained from equation, and the other is obtained from mixing the received and transmitted signals and applying a Lowpass Filter. The goal is to create a radar 2D matrix (No. of samples x No. of chirps) so that I can try post processing to get the Range and velocity. I am able to get the correct range value, but the velocity is always wrong. I am unable to figure out what's wrong. I have posted the code below. Any help would be greatly appreciated.
Thanks in advance.
Thanks in advance.
Code Matlab M - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 close all; clear all; clc; %% Params c=3e8; %%% Transmit side params f0 = 10e9; % dR = 15e-2; % Rmax = 7.5e3; % dV = 0.94; % Vmax = 7.5; B = 1e9; T = 1e-5; Ns = 2048; L = 64; % fdmax=1/(1*T); %%% Receive side params R1 = 70; v1 = 50; % m/s %% Derived Params %---------------- % If Vmax, Rmax, dR, dV specified % T = c/(4*Vmax*f0); % B=c/(2*dR); % Ns = (4*B*Rmax)/c; % L = ceil(c/(2*f0*dV*T)) ; % No.of Chirps %------------------------------- %If B, T, Ns, L are specified Vmax = c/(4*T*f0); dR=c/(2*B); m = B/T; Rmax = Ns*c/(4*B); dV = c/(2*f0*L*T); %------------------------------- % n=ceil(log10(Vmax)); % factor = roundn(Vmax,n) % v1 = factor-v1; %------------------------------- t0 = 2*R1/c; phi0 = 2*pi*f0*t0 - pi*m*(t0^2); fb = 2*R1*m/c; fd = -2*v1*f0/c; % fif_val1 = fb + fd; % For comparison purpose % fif_val2 = m*t0 +f0*2*v/c; % v1=v1-T*1e8/2; fif_val= fb + fd; Ts = T/Ns; Fs = 1/Ts; %Therefore t=0:Ts:T-Ts; % %% Big time scale time_scale = zeros(1,L*Ns); time_scale(1:length(t)) = t(1:end); %% For No.of chirps = L for i=1:L-1 time_scale((i*length(t))+1:(i+1)*length(t)) = t + (T*i); end % time_scale=0:Ts:T*L-Ts; % td=1e-6; td=2*(R1+v1.*t)/c; % R= c*td/2 f_t = f0 + m*t; % f_r = f0 + m*(t-td)/2; %% For L chirps t=time_scale; td=2*(R1+v1.*t)/c; f_t = repmat(f_t,1,L); % New ----------- f_r = zeros(size(f_t)); n = ceil(t0/Ts); f_r(n+1:end) = f_t(1:end-n); f_r = f_r + fd; %---------- % f_r = repmat(f_r,1,L); f_if = f_t-f_r; % f_if(1:n) = 0; st = cos(2*pi.*f_t.*t); rt = cos(2*pi.*f_r.*t); % rt = cos(2*pi.*f_r.*(t+td)); %%%%%%%% % rt = cos(2*pi*(f0(t-td) + m*((t-td)^2)/2)); % t = time_scale; % st = repmat(st,1,L); % rt = repmat(rt,1,L); % f_t = repmat(f_t,1,L); % f_r = repmat(f_r,1,L); fif = rt.*st; fif_lpf = lowpass(fif,max(f_if),2*B,'Steepness',0.8); %% Final IF signal fif_the = 0.5*cos(phi0 + 2*pi*fif_val.*t); % fif_the = 0.5*cos(phi0 + 2*pi.*f_if.*t); %% Plots % xlimit = 2*T; xlimit = T/2; %-------Fig 3 For Big time scale----------% figure(3) subplot(511) plot(t,st); xlim([0 xlimit]) title("Received signal as st = cos(2*pi.*f_t.*t);") subplot(512) plot(t,rt); xlim([0 xlimit]) title("Received signal as rt = cos(2*pi.*f_r.*t);") subplot(513) plot(t,fif); xlim([0 xlimit]) title("IF after Mixing") subplot(514) plot(t,fif_lpf); xlim([0 xlimit]) title("IF after LPF") subplot(515) plot(t,fif_the); xlim([0 xlimit]) title("IF from fif_the = 0.5*cos(phi0 + 2*pi*fif_val.*t);") figure(5) subplot(211) plot(t,f_t); % xlim([0 T/10]) hold on; grid on; plot(t,f_r); ylim([f0-B f0+(2*B)]); xlim([0 T*5]) legend('f_t','f_r') subplot(212) plot(t,f_if); grid on; xlim([0 T*5]) %% Post processing % radar_mat = reshape(fif_the,Ns,L); %% Using the Theoretical IF Signal radar_mat = reshape(fif_lpf,Ns,L); %% Using the Mixed and LPF IF Signal %% Window function window_1D = hann(size(radar_mat,1)); window_2D = hann(size(radar_mat,2)); %% FFT rfft = (fft(radar_mat.*window_1D,[],1)); rfft = rfft./max(max(rfft)); %Normalization rfft = rfft(1:size(rfft)/2,:); % zeroPadding = zeros(size(rfft)); % rfft = vertcat(rfft,zeroPadding); vfft = fft(rfft.*window_2D',[],2); %% Normalization % normalize = vfft./max(max(vfft)); %vfft = fftshift(vfft,2) vfft = vfft./max(max(vfft)); %% Range and Velocity vectors R = 0:dR:Rmax-dR; V = linspace(-Vmax, Vmax, L); figure(4); h=imagesc(V,R,20*log10(abs(fftshift(vfft,2))),[-60 0]); cb = colorbar; set(gca,'YDir','normal') xlabel('Velocity (m/s)'); ylabel('Range (m)');
