Now, we had design a CPU hardware for studying having similar structure as ARM.
How can i simulate and verify its function?
We have no enough time to write a C model to simulate its behaviour.
Is there any other ways? THX
Added after 13 minutes:
We especially want to know the values of the result in the memory, including the general register change
Thans very much!
Do you have an Instruction Set Simulator of this uP???
If yes you could run code in both RTL and ISS and compare the register stack after each instruction. Good code examples would be compiler test code, random assebmy etc
