I actually want to see simulation totally TRX together, which means I have a control signal and want to see if the totally system works. I want to have a descript of control signal and to see if the output of the transceiver is correct.vfone said:If you speak about T/R switch between RX and TX, for link budget analysis just add the insertion loss of the switch on each path (RX and TX). On RX side you will lose some sensitivity due to increase of the NF, and on the TX path you will lose some RF power and some PAE (Power Added Efficiency).
For a nonlinear analysis on the TX path have to take in account the distortions introduced by the switch at high power levels
Yes, I will have a time control signal to tell T/R when to on, when to off, and want to see if the output meet my requirement! I want to simulate the totally process. Please let me know if it is clear now.kspalla said:Is the application is like T/R module where transmit and receive are time multiplexing? Let me understand.
Can you explain more how to set control state and how to use test lab or give me some link how to do it. I will greatly appreciate it.kspalla said:You can use ADS to do this. Define the control state and use test lab.
You can do it using simple S-para simulator.
