[SOLVED] How to simulate a ring VCO using HSPICE
Kristya
Junior Member level 1
I'm learning HSPICE. When simulating a ring VCO, I can't get oscillating wave. It seems to be locked,but i'm sure the connection is right for the netlist is available on Cadence Spectre. Is there any issues.
Thanks in advance.
erikl
Super Moderator
Staff member
Germany
In your transient simulation switch on the power supply.
Kristya
I've tried PWL voltage source on VDD,still doesn't work.
I add a control command .option accurate=1 ,then it work.
Thank you anyway .
