Jan 31, 2007 #1 A ahmed tolba Newbie level 6 Joined Dec 2, 2006 Messages 14 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,281 Location Egypt Activity points 1,381 i installed fedora and it does not see the other drives of windows.....how cani show these drives using fedora???
Feb 1, 2007 #2 szaleniec Newbie level 2 Joined Feb 1, 2007 Messages 2 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,303 Are they ntfs partitions?If yes, try this >> https://www.fedorafaq.org/#ntfs
Feb 1, 2007 #3 III Full Member level 5 Joined Feb 10, 2006 Messages 309 Helped 41 Reputation 82 Reaction score 3 Trophy points 1,298 Location Macedonia Activity points 3,353 Yes fedora ships without ntfs read support get the ntfs packages from an apropriatee fedora reposetory. Added after 2 minutes: and make sure the drivers version is the same with your kernel version or they won't work!
Feb 16, 2007 #4 H hazemafify Advanced Member level 4 Joined Dec 3, 2006 Messages 102 Helped 5 Reputation 10 Reaction score 1 Trophy points 1,298 Activity points 1,903 SA, you can write it in fstab file in path: /etc it will be hidden, so you must show hidden and write the path you will put the windows partitions
