How to set Timer2 to get PWM of 4KHz?
Advanced Member level 6
Bangalore, India
Consider any Clock and explain.
Thanks for the reply. I know how to set Timerx for PWM using Hi-Tech C, C18, XC8 and mikroC PRO Compilers. I wanted to know how to do that using CCS C Compiler as I am new to CCS C Compiler.
You could simply set the appropriate registers, instead of utilizing routines such as setup_timer_2().
Or write your own library of routines which can be easily ported from one compiler to the next.
Also, unlike mikroC, if I remember correctly, CCS provides the source code for its routines.
Take a look in the directories for the source code file and take a look at the routine's inner workings.
BigDog
