Re: Key Pad
The 74C922 or 923 does just that. It scans the keyboard matrix and puts up a Data Valid signal when a key is pressed. You can use this data valid to create an interrupt on your MCU and read the key through 4-5 bits. So the only thing u need from the MCU is 4-5 portpins and an interrupt. Ive used this before and although the 74C923 aint cheap ($10) it does the job perfectly and makes your MCU program really easy and very stable. It SAVES time and then $10 aint allot IMHO.
